Restoring ancient digital watch.
Discussion in 'General Electronics Discussion' started by Jbrt, Oct 2, 2019.
  1. Jbrt
    Jbrt
    28
    Feb 16, 2018
    I purchased one of the first available digital watches in RSA in 1978. I was in the army and the $3 I payed for the watch then was a fortune. I have kept the watch to show the younger generation what a digital watch looked like in the late seventies.
    The watch displayed red numbers. As you can see on the pictures, all types of wonderful crystals grew on the electronics; I presume this was caused by leaving the batteries in for too long. Is there a way I can safely dissolve these growths and use the watch again? I will appreciate any advice.
  2. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    I think there may be a chance of reviving this artifact by using isopropyl alcohol spray. Personally i wouldnt risk cleaning it with a brush because you will certainly destroy the tine wires. the traces look okay under the growth. They knew how to build electronics that last for life back in these days !
    Nice microscope you have by the way.
  3. Bluejets
    Bluejets
    5,250
    1,101
    Oct 5, 2014
    I remember those things...had to find a shady spot to see the display and took 3 hands to operate the buttons.
    Jbrt likes this.
  4. Jbrt
    Jbrt
    28
    Feb 16, 2018
    Thank you for your reply and advice. I understand that I have to be very careful with this 'work of art' :) Can I dip the electronics in alcohol or should I just spray it? I used a Panasonic Lumix FZ 28 with a Raynox Super Macro conversion adapter lens to take the pictures.
  5. debe
    debe
    271
    71
    Oct 15, 2011
    Love the detailed photography.
    Jbrt likes this.
  6. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    I think that you should spray it and allow time to dry. It might take several spray - dry cycles though.
    P.S. It is indeed work of art. I used the term artifact and i meant it :)
  7. BobK
    7,682
    1,688
    How does that remove anything?
  8. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    Spraying helps clean a pcb right? does it not ?
    I believe it is too fragile to be touched even by soft brush. As for diping it, im not sure.
    What would you try if you where in his place ?
    davenn likes this.
  9. davenn
    davenn Moderator
    13,932
    1,981
    HellasTechn likes this.
  10. BobK
    7,682
    1,688
    I still don’t see how spraying with a solvent and letting it dry removes any residue. Can someone please explain it?
    I can see how contact cleaner works on mechanical switches. It softens the residue and then operating the switch brushes it off. But that is not what is being recommended here.
  11. Alec_t
    Alec_t
    3,055
    833
    Jul 7, 2015
    Have you shown them the interesting flora/fauna/crystals that you've shown us in those excellent post #1 pics?
  12. davenn
    davenn Moderator
    13,932
    1,981
    ohhh Bob ;)
    because gently spraying it one of those cleaners I mentioned ( particularly the 2nd or 3rd one)
    will dissolve and wash away the corrosion ... very straight forward, no black magic :)
  13. BobK
    7,682
    1,688
    Oh, so spraying it on really means flooding it with solvent, and letting it pour off. Not spraying it like spray paint and letting it dry!
    That wasn’t clear to me.
    davenn likes this.
  14. Bluejets
    Bluejets
    5,250
    1,101
    Oct 5, 2014
  15. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    Its all right, i thought you knew what we ment :)
  16. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
  17. Bluejets
    Bluejets
    5,250
    1,101
    Oct 5, 2014
    When one has had enough experience one knows when one is beating a dead horse.
