Resonant frequency formula
Discussion in 'Electronic Design' started by Kevin Doyle, Jun 22, 2005.
  1. Kevin Doyle
    Kevin Doyle Guest
    Hi all,
    As we all know Fr of a resonant circuit is 1/(2PiSqrt(LC))
    I saw in the ARRL hand book that they have this formula but have 159 where
    the one is.
    I also saw the use of it here>
    http://www.hamradio-online.com/1999/may/w6bky-13.html
    If 159 is above the line does this mean at Fr the resistance of the tank is
    159 ohms?
    Cheers,
    Kevin.
  2. Andrew Holme
    Andrew Holme Guest
    No. 159 ~= 1000 / (2*pi).
    They've changed the units of f, L and C from Hertz, Henrys and Farads to
    MHz, uH and pF.
  3. Kevin Doyle
    Kevin Doyle Guest
    Oh!
    Thanks for that.
    Kevin.
  4. Yep, a fine example of an attempt to simplify things by making them
    more obscure.
    Stick to SI. Always.
    Jeroen Belleman
  5. Paul Burke
    Paul Burke Guest
    What's your weight, then?
  6. Fred
    Fred Guest
    9.81*kg ? :))
  7. Fred Bartoli
    Fred Bartoli Guest
    Stick to basic physics, always. :)
    Weight is irrelevant: it doesn't depends on you only and changes everywhere
    you go.
    You should have asked the right question: what's your mass?
    Then comes the right answer.
  8. Paul Burke
    Paul Burke Guest
    11 o'clock at St. Mary's?
    Paul Burke
  9. Fabio G.
    Fabio G. Guest
    "Fred Bartoli"
    I remember some people who confused the concept of weight and mass.
    To make clear the difference I finally said: "you can think the mass as
    the number atoms of an object. If you are on the moon or on the earth
    the number of atoms (mass) will not change, but the weight (influenced
    by the gravity force) will."
    Bye
    Per rispondermi via email sostituisci il risultato
    dell'operazione (in lettere) dall'indirizzo
    To reply via email write the correct sum (in letters)
    in the email address
  10. Ah, so a mole of Hydrogen has the same mass as a mole of Uranium. Got
    it! ;-)
  11. Well, irregardless of what element, what do you do with the mole tunnels
    on your lawn?
    Rich
    "There was a young woman named Ells
    Who was subject to curious spells
    When got up very oddly,
    She'd cry out things ungodly
    by the palms in expensive hotels."
    -- Edward Gorey
  12. Rich Grise
    Rich Grise Guest
    Well, you _do_ admit that a gram of gold has the same mass as a gram
    of feathers, right?
    Rich
  13. ....but not the same number of atoms.
