Resonance of Electricity, Skybuck's (crazy?) Theory.
Discussion in 'Electronic Design' started by Skybuck Flying, Oct 16, 2007.
  1. Hello,
    Here is my theory what happens when computers/electricity is continously
    switch on/off leading to damage.
    The electricity follows through the pipes.
    It can no longer flow further and it bounces against the end of the pipe,
    and the electricity flows back in a wave.
    Then the power is put on it again and the electricity wave gets a new boost
    of energy thus increasing the wave if it is done at correct time.
    So then the wave of electricity becomes more powerfull and starts to pound
    on electrical components.
    This is why hardware dies if it is quickly powered on/powered off/powered
    on/powered off in succession ;)
    Bye,
    Skybuck.
  2. Joel Koltner
    Joel Koltner Guest
    I think I'd accept that answer from a grade schooler. :) How old are you?
  3. Tim Williams
    Tim Williams Guest
    Does work wonderfully at RF though.
    Tim
  4. Rich Grise
    Rich Grise Guest
    He's got Asperger's.
    Rich
  5. So you consider it a correct answer ?
    Bye,
    Skybuck.
  6. Joel Koltner
    Joel Koltner Guest
    It's sort of in the ballpark. A very large ballpark, mind you, but at least
    you drove to the appopriate field.
    It's not really so much "wave action" that "pounds" on the electrical
    components but rather large currents and voltages that bring the device up to
    its quiescent state. The canonical example here is light bulbs -- when cold,
    filaments have a very small resistance relative to that desired when they're
    operating "steady state." So, you turn on the wall switch, a huge inrush of
    current goes through the filmanet which physically jerks it around and creates
    localized heating at any thin spots (more so than you have at steady state),
    thus making it much more likely that, if a light bulb is going to burn out,
    it'll do so when it's first turned on.
    In things like power supplies the heating caused by the inrush current to
    filter capacitors may tend to age them a bit, as it does to, e.g., rectifier
    diodes as well (but usually this isn't as big of a deal, and diodes generally
    live much longer than big electrolytic capacitors do to begin with).
    If you want to think about "waves" of electricity pounding components, similar
    to a water hammer in your plumbing, you need to get up to high enough
    frequencies that your system is a signifcant fraction of a wavelength. This
    certainly does happen -- there are plenty of radio transmitters out there
    where, if you forget to attach an antenna, the reflected RF from the
    open-ended coax creates a high-voltage that'll hammer your final output
    transistors to death. :) Unlike a water hammer where you can hear each
    "hammering," though, even if it takes millions of cycles to kill the
    transistors, it still only takes an instant, so usually the radio just quits
    working... or perhaps if you're "lucky" you release a bunch of smoke or it
    starts on fire. :)
    ---Joel
  7. Rich Grise
    Rich Grise Guest
    Not necessarily. Have you ever seen a TDR operate? It uses a step funcion,
    which becomes "DC" (I know, by mathematics, there's no such thing as
    "DC", but for the purposes of real life, it's close enough).
    And that step function can and does "pound" on the electronics. And
    turning it on and off quickly could interact with resonances in the
    equipment, giving you the functional equivalent of standing waves.
    Hope This Helps!
    Rich
  8. Joel Koltner
    Joel Koltner Guest
    Hi Rich,
    OK, I guess I figure waves ought to resemble sine waves moreso than step
    functions, but you're right, step functions can hammer away on stuff too!
  9. Step functions are made from sine waves.
    Takes quite a few of them, though.
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
  10. Hmm,
    Some postings missing on my isp's server.
    I asked Joel:
    Do you consider the explanation to be correct, and here is his interesting
    post/answer, (which IS visible on google):
    to
    cold,
    creates
    generally
    similar
    starts on fire. :)
    ---Joel
    Skybuck again:
    I like especially the light bulb analogy, I have seen that happen to real
    light bulbs when I power them on... a flash happens and then they are dead.
    However I can believe what I want to believe... and I always believed it had
    to do with static electricity... and who knows.. maybe static electricty
    does place a roll as well.
    Here I shall suck a new theory out of my thumb:
    The static electricty flowing from my body onto the light bulb together with
    the rush of power going into the light bulb creates a powerfull tsunami
    destroying the light bulb ! LOL.
    Still I like my analogy of TSUNAMI OF POWER much better... even if static
    electricity does not play a roll...
    Joel's explanation sounds plausible.
    A TSUNAMI OF POWER/ELECTRICTY DESTROYS THE ELECTRONICS DURING POWER UP.
    HOWEVER.
    If this would truely be the cause, then why would the motherboard have died
    after many frequent resets in short time ?
    Why ? I ask ? Why ?
    Why not many days before ?
    It doesn't really fit what I saw.
    I power on the system once maybe twice a day... usually just once a day.
    But only when I power on/off the system in quick succession does it have a
    chance to die.
    Ofcourse it could be that I simply "quickened" the rate of death.
    Or are there are mysterious forces at work.
    JOEL does ADMIT that my RESONANCE THEORY does have MERIT =D
    HIHIHIHIHIHHIHIHIHHI LOL.
    So I still think that the theory might explain it further:
    Some "REST" energy is still present in the system... during quick
    on/off/on/off succession.
    I have seen this "REST" energy before.
    For example pulling the bateries from electronics equipment, maybe even a
    flash light... or what to think about digital watches ?
    Pulling the bateries... and then turning on stuff... shortly gives
    operation...
    I think I have seen this in TELEVISIONS as well...
    It seems there is a small ammount of "rest" energy in the device !
    So the theory goes:
    This "rest" energy could increase or start resonanting... in quick
    on/off/on/off situation.
    Leading to an even greater TSUNAMI OF POWER then usual ;)
    (Complex shit I know ! ;)) :)
    (Also I do wonder why other kinds of lights fail less regularly but ok... ;)
    that's probably worth another topic ;) I especially wonder about
    power-saving-light-bulbs... <- they seem to fail less regularly than
    normal/old/classic light bulbs ! ;))
    Bye,
    Skybuck.
  11. "Joel Koltner" <> skrev i en meddelelse
    Old enough to drink a bottle of bleach to become the next Michael Jackson -
    well one hopes (in vain, but one can at least dream)! news2020 is not easily
    replaced.
