Resistors or not?
Discussion in 'General Electronics Discussion' started by KTW, Oct 11, 2016.
  1. KTW
    KTW
    273
    15
    Feb 22, 2015
    Does anyone know if these light panels have resistors built into them or do they even require them?
    Thanks.
    [​IMG]
  2. Harald Kapp
    11,653
    2,695
    Do you have a datasheet or a link?
  3. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Do you have parts numbers?
    Look in the datasheets, there is your answer.
  4. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    Resistor, Not Likely it is built in.
    Mainly because the resistor will depend on your Supply Voltage.
  5. KTW
    KTW
    273
    15
    Feb 22, 2015
    I'll hunt for a data sheet, they are readily available on ebay but they just list the voltage as 12 volts DC.
  6. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    If they are listed as "12V" they need no resistor.
    They should be the automotive type,"stealing" 12V from existing 12V sockets in a car,
    via the black female connector/adapter inserted instead of a light bulb.
    The LED matrix with the male connector is then plugged in the female to supply the 12V to the LEDs.
  7. (*steve*)
    25,497
    2,839
    Those panels work fine at 12V at a particular temperature, on a particular day, when the phase of the moon is right.
    At other times and in other conditions they will either draw less current (besides being a little dim this is no problem) our more current (which is a problem).
    Technically, these LEDs often use excess bulk semiconductor to increase their series resistance. This helps but is no guarantee. They are built to a (very low) price.
