W
Weinberger Hans
Hello to all.
Thanks to all for your advice, it has helped us go ahead.
The step down transformer I got from your sources works well though it
measured 123V ac output instead of the 120V ac, but the alarm is
working well and the dialer function surprisingly also. I checked up
circuit and it seems neither SMPS nor a transformer , but is as Jim
Thompson had said that a capacitive reactance with relative circuitry
of Zeners , diodes and so forth is used. I
am in the act of modifying the circuit board of 1 of the modules to
which the radio signal will be transmitted in case of fire and as also
this is supposedly powered from 110V I want to change it to accomodate
the 232V my mains is delivering.
I'm replacing some of the lower voltage components with higher
voltage / power components I had some problems in differentiating
between a varistors and capacitors but it seems solved.
They used the same color , very funny I think.
My supplier sent me some higher watt resistors which are smaller then
the originals on the board ... very fishy I think. What do you say?
Hans
Hans
