Resistor value
Discussion in 'Datasheets, Manuals and Component Identification' started by ADRT, Jan 26, 2015.
  1. ADRT
    ADRT
    192
    32
    Nov 25, 2014
    I removed this resistor from a circuit. It quite obviously got very hot. image.jpg image.jpg I can't quite make out the color code. Looks like brown, yellow, white, gold but that makes no sense cause white is not a multiplier. Reads 90ohms. Any ideas?
  2. ADRT
    ADRT
    192
    32
    Nov 25, 2014
    There are also some 100 ohm resistors and a couple of 220 ohm resistor in the circuit that are similar power dissipating type resistors.
  3. davenn
    davenn Moderator
    13,793
    1,938
    probably is a 100 Ohm resistor with heat faded colour bands
    no reason to suspect otherwise
    ADRT likes this.
