Resistor Substitution(s)
Discussion in 'General Electronics Discussion' started by trope, Aug 12, 2011.
  1. trope
    trope
    12
    Aug 9, 2011
    Is there a rule of thumb for substitution of resistors if you don't have one available?
    For instance.... let's say you need a 82K resistor... what would be an acceptable substitution?
    Thanks from a new guy.
    John T.
  2. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    That all depends on the application, maybe 10k, maybe 100k or maybe 82.000k
    82k is a standard value in the E12 series, so you should be able to find one. It will need to have adequate pwer and voltage rating.
  3. daddles
    daddles
    443
    3
    Jun 10, 2011
    There is no rule of thumb because as duke37 said, it depends on the application. Note there are programs that can help you make up a resistance you need from other resistors you may have on hand. If you can build a C++ program, there's one in here (get the resistor.zip file). It also calculates voltage dividers for you.
