resistor question..
Discussion in 'Electronic Repair' started by Ronald, Mar 11, 2008.
  1. Ronald
    Ronald Guest
    My mind isn't thinking clearly.. I need some quick advice..
    1 ohm resistor.. couldn't I substitute it with a piece of straight
    wire?
    I know that would be 0 Ohm.
  2. James Sweet
    James Sweet Guest
    If a piece of straight wire would work, that's probably what they would have
    used to begin with. What's the application?
  3. Ronald
    Ronald Guest
    Projection TV... the Convergeous circuit. before the stk392-110...
  4. James Sweet
    James Sweet Guest
    Is it a fusible resistor?
    I would say it should be ok to test the set using a piece of wire, but I
    would not return it to service without replacing witht he correct part.
  5. Ronald
    Ronald Guest
    True... I ordered new stk's and resistors... my theory was right.. I
    replaced the resistors before on this tv with wimpy 1 ohms last
    night.. tv worked great until they failed. so Bad Stk's and with me
    jumping them just now shows the stks to now have failed. so thanks
    for the help!!
  6. Guest
    Damn spammers everywhere !!!!
    PLONK
  7. bz
    bz Guest
    wrote in 4ax.com:
    X-Complaints-To:
    if they get enough complaints, they might start putting some safeguards in
    to prevent spamming from gmail accounts.
    bz 73 de N5BZ k
    please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
    infinite set.
    remove ch100-5 to avoid spam trap
