C
Chris Carlen
Greetings:
I wish to sample a raw 75V 125kHz H-bridge output. The two H outputs
will go to a differential amplifer/attenuator to create a single ended,
low-level sample of the output voltage. Trouble is, I don't want the
raw signals running along my PCB from the high powered department to the
low level zone and radiating spikes all over the place. Thus, I'd like
to slow the edges just a bit before routing them long distances.
So use an RC. Trouble is, for instance a 1.25MHz cutoff filter with a
500 ohm resistor could potentially dissipate 11.25W in the ressitor on
transitions, even though the RMS current is only 17.7mA.
The question is, can a simple 0.25W 1210 resistor handle the transients?
If I make the resistors larger, then they contribute to errors in the
differential amp gain by being close to its input resistance. Well just
make them a part of the input resistors you say? Ok, but then doesn't
the AC CMRR suffer if the caps aren't matched?
Looking at the Panasonic ERJ 1% series, they allow only 2.5x rated power
for short term overload. But I suspect this isn't really the applicable
spec for this situation. There is nothing in the datato help one figure
out the device's tolerance to repetitive VERY short term overload, where
average power is still well within the continuous rating.
Comments appreciated.
Good day!
_______________________________________________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected]
NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
Good day!
[email protected]
