R
realexander
Of course, everywhere I see a circuit with an LED, there's a current
limiting resistor. But I'm wondering if, in my case, it's necessary.
I have an eight digit multiplexed display, using 14 segment LEDs. A PIC
selects the digit and turns on its common anode through an NPN
transistor (and I also don't have a resistor between the PIC and the
transistor's base). The transistor's collector is at +5 with no current
limiting resistor. The PIC selects the individual segments within a
digit by having its I/O lines tied to the cathodes and setting the
output to 0 to turn on the segment. There's no resistor on the cathodes
or the anodes.
Everything seems to work great; the LEDs light at a reasonable
brightness (though there's some variation in the brightness - I learned
too late why I should've bought common cathode LEDs instead of common
anode). If I put in current limiting resistors of 220 ohms, the LEDs
are dimmer than I'd like (remember that the display is multiplexed, so
each digit is off 7/8 of the time, or more if I use PWM to dim the LEDs
in a dark room).
Is this a "safe" configuration? Can I get away with no resistors since
each LED is off most of the time? What about the PIC - the LEDs might
be off most of the time, but some of the PIC's I/O lines are
potentially sinking current all the time. Am I going to eventually fry
my LEDs, PIC, or both?
Bob Alexander
or the anodes.
in a dark room).
Bob Alexander
