Resistor identification
Discussion in 'Troubleshooting and Repair' started by J.C., Mar 13, 2015.
  1. J.C.
    J.C.
    Mar 13, 2015
    I am a new member and appreciate any help given.
    Question: Can anyone identify the value of this 5 band resistor?
    Colour bands are equidistant from each other and hence I can't decide whether to read left to right or right to left.
    Bands: Black - Gold - Gold - Black - Brown
    This resistor is fitted on the primary section of a tablet adapter charger and is fitted after AC input before the Bridge Rectifier.
    When checked with a Digital meter I got NO readings of value (could be open!!!).
    Thanks in advance for your assistance.
    J.C.
    T
  2. debe
    debe
    267
    68
    Oct 15, 2011
    Looks like a 1 ohm metal film resistor being used as a fuse.
    davenn likes this.
  3. Luis Costa
    Luis Costa
    30
    3
    Mar 13, 2015
    seems to be intentionally shorting.
  4. davenn
    davenn Moderator
    13,833
    1,950
    BN BK GD GD BK is the correct way
    I agree with debe ..... it is in the live line between the wire to the board and the bridge rectifier
    what specifically did the meter real ? 0L or 0.0 .. 1.0 - 0.1
    if 0L then yes the resistor is open circuit
    have no idea what you mean by that ??
    DAve
    (*steve*) likes this.
  5. J.C.
    J.C.
    Mar 13, 2015
    Once the meter was turned on the reading was 1.
    On checking the resistor, it still read 1.
    I wasn't sure whether the meter was reading correctly so I rechecked it against a good known value resistor and it read correctly.
    So I rechecked the resistor in question and still read 1.
    J.C..
  6. davenn
    davenn Moderator
    13,833
    1,950
    show us a pic of your meter with the resistor connected :)
    just so we know you have it in the correct setting
