Resistor for power source minimum load
Discussion in 'General Electronics Discussion' started by Steveggz, Oct 24, 2017.
  1. Steveggz
    Steveggz
    15
    Oct 7, 2017
    I'm trying to power a small PWM generator from ICStation that uses less mA than my Mean Well minimum load. Would putting a resistor in parallel (between the positive and negative wires) before the unit help reach that minimum load?
    The power supply is 5v and needs at least 200mA give power. If the above is correct is this formula correct, 5/.2= 25Ohm resistor at 2W?
  2. (*steve*)
    25,500
    2,840
    That would be fine.
    Steveggz likes this.
  3. Steveggz
    Steveggz
    15
    Oct 7, 2017
    Thank you!
