Resistor colour code
Discussion in 'General Electronics Discussion' started by remzy, Dec 10, 2016.
  1. remzy
    remzy
    47
    Jun 12, 2015
    I've been dealing with fixing and making electronic projects for a few years now but my knowlege is still not perfect. I need help about this resistor. I just haven't ever seen this colour code on them before: Black, gold, silver, red and blue
    Here is a picture.
  2. Harald Kapp
    11,268
    2,577
    This may be an inductor, not a resistor.
    Inductance 0.62µH
    remzy likes this.
  3. hevans1944
    hevans1944 Hop - AC8NS
    4,592
    2,149
    Jun 21, 2012
    Or, if it really IS a resistor: 0.62 ohms. 62 is the two significant figures from blue and red bands, silver band means multiply significant figures by 0.01, gold band means 5% tolerance; ignore the black band.
    If it IS an inductor, as Harald mentioned, 0.62 μH is a quite small value. You may not be able to distinguish this component from a low-valued resistor.
    davenn and remzy like this.
  4. remzy
    remzy
    47
    Jun 12, 2015
    I'm pretty sure it's a resistor because its marked as one on the pcb.
  5. hevans1944
    4,592
    2,149
    Jun 21, 2012
    0.62 ohms might be hard to measure with a multi-meter. You could connect it to a constant-current source and measure the voltage drop to verify the resistance. No constant current source handy? Just wire it in series with a 100 ohm resistor and connect the series pair to a constant voltage source of about five to ten volts. Measure the voltage drop across the "0.62 ohm resistor" and use the voltage divider equation to determine the resistance.
  6. Harald Kapp
    11,268
    2,577
    An unmistakable sign.
    hevans1944 likes this.
  7. remzy
    remzy
    47
    Jun 12, 2015
    I would've done that but the resistor is blown from the other side. I've just took a picture of it where you can see the colours clearly. I didn't know about that method. Thank you! :)
  8. davenn
    davenn Moderator
    13,798
    1,939
    you read the colour code back to front ;)
  9. remzy
    remzy
    47
    Jun 12, 2015
    I've realised that later on. Thank you :D
    davenn likes this.
