Resistor colour code problem
Discussion in 'Electronic Repair' started by [email protected], Dec 31, 2007.
  1. Guest
  2. Probably 2.2ohm 1/4 watt red 2, red 2, silver 10% gold 5%
    (tolerance) it acts like a fuse. Better check for a short after that
    or you'll be burning those as fast as you can replace them.
  3. Arfa Daily
    Arfa Daily Guest
    I think the value is lower than that. Silver as a multiplier is x.01, so
    probably 0.22 ohms at 5% tolerance.
    Have a look at
    http://www.dc-daylight.ltd.uk/Valve...nent-Colour-Codes/Component-Colour-Codes.html
    which should confirm it. I would agree, however, that there is probably
    something else wrong, for the resistor to have failed like this. If it is an
    output transistor emitter resistor, then the transistor it is connected to,
    as well as possibly others in the vicinity, is almost certainly fried.
    Arfa
  4. Jamie
    Jamie Guest
    ..22 ohms, 5% ?
    "I'd rather have a bottle in front of me than a frontal lobotomy"
    "Daily Thought:
    SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT
    THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
    http://webpages.charter.net/jamie_5"
  5. mm
    mm Guest
    He's the kind of guy who would pat you on the back in front of your
    face, and
    If you are inclined to email me
    for some reason, remove NOPSAM :)
  6. Peter Kolbe
    Peter Kolbe Guest
    Maybe the R's are still good (even tho' overheated)
    If I am correct, most resistors would fail Open-Circuit.
    Perhaps a Low Value Ohmmeter will be able to give insight into the value.
    P
