Resistivity question help
Tea cup
Mar 22, 2018
Mar 22, 2018
The question is : Copper wire, with a diameter of 1.5mm, must be of such a length as to give a resistance of 0.6 ohms. calculate the length of this wire. Take the resistivity of copper as 0.017 microhm metres.
Harald Kapp
13,737
13,737
resistance = resistivity / cross sectional area * length
reverse this equation to get the length from a given resistance.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
If I remember correctly, the 0.017μΩ meters refers to a 1 Metre cube of solid copper. Calculate from there.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
No, I think it refers to the actual resistance of the said 1 Metre cube.
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
Resistivity is an intrinsic property of a material and does not depend on the resistance value of any size or shape. In other words, a cubic foot has the same resistivity as a cubic meter of the same material.
Ratch
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
Calculations are straight forward. Keep the units consistent.
Ratch
The Electrician
Jul 6, 2012
117
Jul 6, 2012
117
If by the phrase "resistance of the said 1 Metre cube", you mean the resistance measured between two of the plane surfaces of the cube which are on opposite sides of the cube with a perfect conductor used to make the connection to each face, you should be aware that the resistance will be the same for any size cube.
