Resistance power rating for this AC dimmer circuit?
Discussion in 'General Electronics Discussion' started by Laciecion, Nov 24, 2019.
  1. Laciecion
    Laciecion
    Nov 24, 2019
    Hi everyone!
    I was reading this really nice page about light dimmers when I saw this diagram for a AC dimmable led bulb dimmer and thought about giving it a try.[​IMG]
    It is build around a FL5150 IC, here you can find the datasheet. My question is about the power rating needed for the resitors and voltage rating for the capacitors, I have seen it using 1206 1/4W SMD resistors but I am not sure if that is safe enough.
    It would be nice if someone could help me to figure this out, hope this is not a stupid question I am getting started with electronics and learning a lot in this forum.
    Thank you!
  2. Harald Kapp
    11,997
    2,813
    1/4 W power rating is probably o.k.
    Note that Rsense1 and Rsense2 need to be rated for 230 V AC or higher (at 2MΩ power dissipation will still be very low).
    You'll have to observe safe isoaltion gaps between different traces/wires at high differential voltages.
    This circuit is connected to dangerous live voltages on mains level. This is not a suitable circuit to get you started with electronics. I suggest you start with low voltage circuits, possibly battery powered or powred by a low power voltage source (e.g. a 5 V USB power supply from a charger).
    bertus likes this.
  3. bertus
    bertus Moderator
    2,278
    851
    Nov 8, 2019
    Hello,
    @Harald Kapp said, use a low voltage source.
    This is a solid advice.
    Direct mains powered equipment will be dangerous and can even be leathal.
    As for safety rules, you could have a look at the following page:
    http://www.repairfaq.org/sam/safety.htm
    Bertus
  4. WHONOES
    WHONOES
    1,190
    322
    May 20, 2017
    I will add my voice to those urging extreme caution which amounts to DON'T. As advised, start with something that requires no more that 5 to 15V dc.
    Cannonball and bertus like this.
