Resistance and Inductance
Discussion in 'General Electronics Discussion' started by tedstruk, Mar 19, 2017.
  1. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    If say RS was out of 18k resistors and you couldn't find one in your shop...
    could you make 18k out of a 22k resistor and an induction coil?
  2. (*steve*)
    25,448
    2,802
    No.
  3. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Resistors in series, add the resistances.
    Resistors in parallel, add the conductances which are the inverse of the resistances.
    1/A + 1/B = 1/C
    So 1/22k + 1/B = 1/18k
    so 1/B = 1/18k - 1/22k
    Using a reverse polish calculator and using ks.
    18 1/x
    22 1/x -
    1/x
    gives 99
    so put 100k resistor in parallel with 22k, the shop should have one of these.
  4. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    They didn't
    RS have 2 9k's, but I got a pack of 22k's, from what you told me, I can lessen resistance by placing resistors in parallel, where say .04 ohm motor will stop at .04 ohms of resistance! yeah I did that! Same process but in series, with less math! I wonder if that same motor will stop with parallel resistors?(I tried it once and it didn't work. had something to do with the differences and feedbacks of AC-DC source)
    Heres one that I remember toying with in my younger years!
    "They don't make some of the stuff you will require so you will have to make your own." teach
    I wanted a megaohm pot....
  5. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    Calculating resistors in parallel---
    count the number of conductors - "duh... I got like 2 resistors in there"
    1 divided by each resistor value and add them together.
    (remember to convert all your values to the same value where ohms is king and the polish are itallian)
    so
    1 / 100000 =.00001
    + 1 / 22000 = 5.45454~
    .00001 + 5.45454~ = 5.4545456
    1 / 5.4545456 = .18333 (where infinite values of 45 are considered polish and modern calculators do the work for you...) dumps out somewhere around 18k in my case about 17k... On the DDM scale that is.
    The POT above is about 5mohms.
  6. BobK
    7,682
    1,686
    Uh, 1/22000 is not 5.4545...
    Try again.
    I get 18033
  7. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    I do not understand why polish are italian.
    If you have a calculator with a 1/x key, then things can be very easy, you do not need lots of intermediate calculations. I like the reverse polish calculator since I have used it for 30 years and get my numbers in a twist when using a more usual arithmetic calculator.
    To calculate the resistance of 100k in parallel with 22k, run in thousands to limit the number of key presses.
    Here goes
    100 1/x
    22 1/x +
    1/x
    gives 18.033.
    Since we were running in thousands, the answer is 18k033 as Bob found.
    You could instruct me in how to use an arithmetic calculator.:)
    (*steve*) likes this.
  8. BobK
    7,682
    1,686
    100000
    22000
    1/x
    18032.78689
    On my TI calculator
  9. (*steve*)
    25,448
    2,802
    Or for calculators with dubious handling of precidence but having a memory:
    100
    STO
    22
    RCL
    STO
    RCL
    I love my RPN calculators. It makes all this nonsense redundant.
    OBW0549 likes this.
  10. OBW0549
    OBW0549
    159
    118
    Jul 5, 2016
    Yup.
    22000
    1/X
    100000
    1/X
    1/X
    (Display: 18032.78...)
    Done.
  11. BobK
    7,682
    1,686
    When I was in grad school at Purdue, we had a calculator Olympics. The HP RPN people always won, until TI came out with operator precedence and nested parentheses. Then the TI people always won.
  12. (*steve*)
    25,448
    2,802
    Yes, for any equation you have to mentally perform the infix to postfix notation conversion. And where the calculator can do this quickly, the algebraic I notation calculator will have the lead.
    Any calculator using algebraic notation must do the conversion to RPN (or similar) in code (even if they do it very badly). This requires memory and processor cycles that the early calculators did not have in abundance. I remember some AOS calculators literally taking seconds to display a result.
    HP eventually switched to AOS for student models because to do otherwise would be to be making a significantly different thing that teachers would have to allow for. At the same time, galloping featuritis pretty much killed the handheld calculator as it tried to emulate a computer or be all things to all people.
    I taught my wife to use an HP-28 (AOS) while I still used my HP-41 or occasionally an HP-21 at work. (As she pointed out, what use is a calculator collection of she couldn't use any of them)
    It is also interesting to note that the HP calculators seem to have survived the decades far better than the TI models. And that's a shame because they were pretty much fierce competitors at the time, forcing all sorts of technology into the hands of people like myself. It is interesting to note that for a long time the Space Shuttle carried HP-41's along for a number of purposes including very basic deorbit burn calculations. http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv001.cgi?read=2577
  13. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    Dad used to grill me on fractions... I new already that 1/ a number was not 1, from working on lathe calculations in the shop.
    Removal of zeros is part of machinist, and was a small part of pre algebra. I had heard the term "polish calculator" before, but I have to be honest... the first time it didn't work right for me and I still laugh about it today!
  14. (*steve*)
    25,448
    2,802
    The only Polish calculators I can conceive of come from Poland. RPN is never called "Polish" (to my knowledge) and it's connection with Poland is via the nationality of the author of what has become known as Polish notation (a form of notation developed for symbolic logic, and only as an afterthought found to describe arithmetic). Your confusing use of non standard and apparently unique terminology makes you one of the more frustrating people to try to understand.
  15. WHONOES
    WHONOES
    993
    261
    May 20, 2017
    I use the following formula:
    Where
    Ra = required Value
    Rx = Known Value
    Ry = Unknown Value (to be placed in parallel with Rx)
    Ry = (1/(Rx - Ra) / Rx) *Rx
    It takes just a few seconds on a hand calculator. I have a spread sheet with all sorts of formulae on it (including this one) which make life a lot easier since I don't have to remember all of them and it takes no time at all to get a result.
