R
Robert11
Hello:
This is a sort of follow up to what I posted a while back.
Thanks again for the replies.
Am still wondering, a bit, about residential street wiring, and in
particular the transformer
they use to bring the 12.8 KV line-to-line down to 220 V for a house.
What I am confused about is the following:
They seem to take a single lead off the three wires comprising the three
phase (12.8 KV line to line I am told), and
bring it to the (usually the top) of a pole transformer that serves perhaps
a dozen houses on the street.
Then for the next dozen or so houses, I imagine they tap off a different
phase wire, etc.
**Wouldn't they have to bring in two phases to the transformer on the
primary side ? **
Where's the ground, or return for the primary ?
The secondary seems to comprise three leads, which I guess are 220 V, with
probably a center tap for the ground.
This goes to the house.
It's the primary I don't understand, in that they only seem to use a single
wire off the three phase high voltage 3-wire pole system.
What do they use for a ground (or return) ?
Or, is the primary wired as an auto transformer, with one leg of the primary
connected to one leg of the secondary.
Kind of doubt it, but if not, how is it done ?
phase wire, etc.
primary side ? **
