G
Gerry OGrady
11 September 2003 6:52 PM
I have three identical 12VDC batteries that I would like to use for 40 amp
36 Volt DC motor testing. I need a schematic on how to hookup the batteries
in series (36V) for testing the motors and when the batteries get discharged
I can activate a switch to connect the batteries in parallel (12V) for
charging with a 12V battery charger. I currently swap the connections
manually which is time consuming at best. I can envision using a multi pole
high power relay to accomplish this. I just can't get my brain around the
actual wiring.I would appreciate a schematic or a link to any website that
illustrates the solution.
Cheers ...Gerry
[email protected]
Cheers ...Gerry
[email protected]
