Representing offset voltage of opamp?
Discussion in 'General Electronics Discussion' started by eem2am, Jun 27, 2013.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
    Hello,
    I am trying to add an offset voltage of 4.5mV into each of the opamps U1 and U2 in the below schematic.
    (in the actual circuit, the MCP601 opamp will be used rather than LT1006)
    Have i put the offset voltage source in the right place? (right way round etc)?
  2. Harald Kapp
    11,956
    2,793
    The placement looks o.k. The orientation depends on the sign of the offset voltage. Since the offset is a measure of inequality between the two inputs, it can be either positive or negative.
