S
Skeleton Man
Hi all,
I have a heater that has 2 heat settings, controlled by a dial (variable
resistor).. you turn the dial one way about 2 full turns it goes onto the hot
setting, you turn it about 2 turns the other way it goes onto the wam setting..
My problem is that the dial is broken.. the shaft has broken at the base and
just sits there, making it very difficult to change heat settings..
I don't know how to go about getting a replacement.. because it's more like a
switch than a variable resistor.. in the warm position it reads 100 ohms, in
the hot position it reads as a dead short (0 ohms).. there's no inbetween
setting... is this still a variable resistor/pot or does it has a different
name ?
The markings on it are as follows:
605
0-40
392A
btw, are all variable resistors pots ? or is there a difference between the two
Regards,
Chris
name ?
605
0-40
392A
Regards,
Chris
