Replacing the FBT
Discussion in 'Electronic Repair' started by zehelmer, Jul 27, 2005.
  1. zehelmer
    zehelmer Guest
    Hi ALL,
    I'm not experienced in TV repair... but my F-19 TV went down and I
    could see sparks leaking from the FBT (Eldor 1352.5016).
    I replaced it with an equivalent one (HR-8325)... bout now there is no
    raster, although the CRT heaters are lit and a sudden light appears
    around the screen at the demagnetization pulse.
    Have I to readjust some values or replace some other components?
    Which checking steps should I follow to bring it back to life?
    Please help me :idea: to solve this "black-out" :roll:
    Many thanks in advance
    zehelmer
  2. James Sweet
    James Sweet Guest
    Are you sure no modifications were required for the HR sub? Also don't
    forget to adjust the Screen control on the fbt if it has one. You might also
    have interchanged the focus and G2 wires to the neck board.
  3. Jonathan
    Jonathan Guest
    And maybe the line output transistor got fried when the old FBT died...
  4. b
    b Guest
    turn up the screen control, a raster should appear. if you get a
    horizontal line check the fed to the vertical IC.
    Ben
