replacing rubber belts
Discussion in 'Electronic Repair' started by les, Jul 22, 2005.
  1. les
    les Guest
    Hello........
    I have a number of older machines (VCR,answering,...)
    that have old, worn belts.
    I'm having a hard time sourcing replacement belts. I assume
    someone still has them (even the manufacturers are dropping
    these)
    Please send me some ideas...........TNX
    Les KA9GLW
  2. Cliff Top
    Cliff Top Guest
    CPC at Preston still have a pretty comprehensive selection
    Andrew
  3. N Cook
    N Cook Guest
    Some hints for cutting your own, especially the flat ones that seem
    impossible to get. Cut down inner-tubes may vary in thickness and
    look awful but as the tension in a band is constant it seems to be ok
    for all but the most discriminating of uses.
    tips buried on
    http://www.divdev.fsnet.co.uk/tips.htm or
    http://www.divdev.fsnet.co.uk/tips2.htm
  4. Guest
    Les:
    Do you Google search ? or Yahoo ? or another search engine ?
    In less than 10 seconds after I typed in "vcr belts" and clicked on
    search web I had 144,000 hits with the first several dozen being good
    sources and suppliers for the various equipment belts you are seeking.
    Let your fingers do the walking.... I find that Google Web Search is
    real good for finding what you need.... always try it first.
    Lots of belts are readily available and are NOT hard to source. The
    Internet is a good tool to use to find suppliers for these and other
    "hard to find" parts.
    electricitym
  5. GregS
    GregS Guest
    I would also recommend Gigablast.
    http://www.gigablast.com/
  6. les
    les Guest
    THANK YOU !
    I'll jump over there and look. All my old sources "dried up"
    due to the integration of newer IC's, as you well know.
    Les
