dimitristephan
- May 14, 2012
- 2
- Joined
- May 14, 2012
- Messages
- 2
Hello people,
My old black and decker electric screwdriver had lost a lot of torque and speed after a
couple of years of use, so I decided to replace the 3 x AA batteries that were connected in
series by one 18650 lithium Ion battery of the same voltage rating but higher
capacity. However, since the battery is not protected against overcharging/discharging,
leaving it on the charging base has actually caused the battery to get overcharged to
around 4.6 V. The nominal voltage of such a cell is 3.6 V, but are generally charged to 4.2
V. For some reason, the charger is not stopping the charge at 4.2 V. Could it be that the
battery has a lower internal resistance than 3 AA's in series? There is a serious risk of fire
and/or explosion if I do not find a way to limit the terminal voltage to 4.2 V. Is there any
way I can do so? Your input is much appreciated.
Thank you!
Thank you!
