Replacing crystal with external clock signal
Discussion in 'Electronic Basics' started by Florian, Sep 3, 2006.
  1. Florian
    Florian Guest
    I have a chip that wants a specific low-frequency (38k) clock crystal,
    which are somewhat hard to find and pricy. I could synthesize a 38k
    clock signal, but the chip is not designed to accept an external clock -
    it wants that 38k crystal and a 10pF series capacitor between two pins.
    Would it be possible to trick the crystal driver into syncing to an
    external clock by proper attenuation and filtering? What sort of
    voltages would be present in a running oscillator like this? Am I
    likely to damage the chip by experimenting?
  2. PeteS
    PeteS Guest
    What device are you using?
    These devices usually use an oscillator across the pins of 'XTAL1',
    'XTAL2' or some such. In the documentation it usually specifies which
    pin is the output of the amplifier and which is the input. You should
    be able to drive the input side without problems from an external clock
    at the appropriate levels, but what they are depend on the device.
    Cheers
    PeteS
  3. Florian
    Florian Guest
    The chip is a BA1404 FM transmitter. I found a datasheet at
    <http://www.radiochips.com/images/ba1404v2.pdf> but I can't tell from that
    which pin is the input. Am I likely to fry the output if I try to drive
    that?
    Any guesses as to the voltages to start experimenting with? I'm planning to
    run the chip at 1.5V.
    Thanks for your help!
  4. Florian
    Florian Guest
    Ok, I think I've got things figured out. Powering up the BA1404 and looking
    at the two unconnected XTAL pins with a scope, pin 5 is quiet and pin 6 puts
    out a high-frequency signal or noise (looks like a solid band between ground
    and Vcc=1.50V on my 20MHz analog scope, can't find anything periodic in
    it). Thus I infer 5 is the input and 6 the output.
    I have an ATtiny12 producing a 38kHz clock and put that through a voltage
    divider (47kOhm + 10kOhm yielding a bit under a volt for high) into pin 5.
    This makes pin 6 produce a neat square wave at 38kHz, 0 to Vcc, and I get a
    19kHz signal with a DC bias out of the Pilot pin, so on the surface things
    would seem to work.
    Now comes the fun part where I get to mess around with radio frequency stuff.
    It remains to be seen whether the internal RC oscillator on the ATtiny is
    stable enough to produce decent output, or if I need to add an external
    crystal to /that/. At least I have some handy.
    A big thank you to PeteS, who's having trouble posting, for his helpful
    email!
  5. PeteS
    PeteS Guest
    You are most welcome. Playing under the hood with 'undocumented
    features' is fun :)
    Cheers
    PeteS
