Replacing Casio watch battery - problems
Discussion in 'Electronic Repair' started by Mike, Apr 10, 2005.
  1. Mike
    Mike Guest
    I have a Casio digital technical watch that seems to be broken. I was
    hoping that taking the battery out may reset it so it will work right.
    Unfortunately, I can't get the battery out. I was hoping
    someone here might be able to help me.
    The model number is: CA-53W (437). I've read the instructions a
    zillion times but they don't appear to be entirely accurate. There's
    some sort of metal plate covering the battery that won't lift up or
    turn. The instructions say that a screw(s) needs to be removed first.
    However, I only see one screw in the watch and no matter how much I
    turn it, it won't come out or lift up.
    The watch has a time display on it but none of the buttons work. They
    stopped working a few months after I got it about 13 years ago. I took
    it to two repair shops but they wouldn't/couldn't touch it. Oddly
    enough, the original battery (CR-2016) is still working.
    Can anyone help me?
  2. NSM
    NSM Guest
    Any half way decent radio repairman could fix it but you won't want to pay
    for the repair!
  3. testortool
    testortool Guest
    A good jewelry / watch shop will change out the battery for a few bucks in
    labor if you haven't already broken something.
  4. Bram Stolk
    Bram Stolk Guest
    it is a tricky way but it can be done...
    remove the clockworks completely (that's including the plastic casing) from
    its housing
    separate the plastic frame from the clock
    remove the little screw you spoke about earlier
    look at the edges of the big battery clip holder, they latch to the clock
    housing at three locations,
    pry-off the cover plate...Presto battery can be removed. Before you
    reassemble in reverse order make sure that the pushbuttons in the housing
    can move freely, lube with light oil if necessay or remove them completely
    to remove sweat and dirth
    Unless you have some emotional ties with this watch donot even start all
    this work and replace it by a new one...
  5. Mike
    Mike Guest
    Thanks for the help. But can anyone tell me why the buttons on the
    watch won't work but the display still works? I only wore it once or
    twice before it stopped working. I didn't open it before then or hit
    it against something or get it wet. I'm also baffled as to why the
    original battery is still working some 13 years later when Casio says
    it should last 5 years. I've been thinking of buying a new watch
    similar to this one but I'm hesitant to since I had such bad luck with
    this one. I was just hoping that maybe it would be easier and cheaper
    for someone to fix it now with all this new technology then it was
    years ago.
  6. Bram Stolk
    Bram Stolk Guest
    Probably you have to hold button for a few seconds to get active, or you
    must press and hold two buttons simultaneously, or your buttons just donot
    move far enough inwards to make the proper contact. Try to short circuit
    contact with e.g needlepoint when backplate of watch is removed..
  7. Because while there are switches on the module, the buttons you press
    are only the buttons to manipulate those switches. If the module isn't
    properly aligned with the buttons, then you will have problems activating
    the switches.
    I've changed batteries in such watches, and had to reopen the case
    to adjust the alignment a bit in order to get the switches right.
    And my memory is that the alignment could be off enough to cause
    problems and still not be visually noticeable.
    As for batteries, the estimate may have no basis. Or it may be
    based on actual use, which includes activating the backlight. If
    you aren't using the watch, you'll never activate the backlight, and
    that's what uses up the battery. INdeed, I've not found the estimate
    of battery life on the watches I've had very accurate, since I use
    the backlight quite a bit and that wears out the battery much faster.
    Michael
  8. NSM
    NSM Guest
    Because it's a Casio!
  9. Bill Jeffrey
    Bill Jeffrey Guest
    I had a multi-function / multi-button Casio that did this. After I
    owned it a few years, I found that I had to press one of the buttons
    harder and harder to make it register. I changed the battery, but it
    didn't help. This happened over the space of only a few weeks, and then
    another button started doing the same thing. I concluded that the
    conductive material on the buttons had either worn away or gotten dirty,
    and since I couldn't get ready access to the buttons, I abandoned it.
    Sorry
    Bill
  10. jakdedert
    jakdedert Guest
    I'm still using the Casio that I found lying in the street around 15 years
    ago. I've put several new bands on it and cleaned the gunk out of the pins
    which activate the switches, as well as changing out several batteries.
    I've bought--or been given--several watches in the intervening years; but
    this is the only one which seems to keep working. I wear it 24/7, even in
    the shower and pool. It gains about a minute/month when on my wrist, and
    loses about the same if left in a drawer...undoubtedly due to temperature
    variation.
    If you'd ever had a Casio, you'd probably not have written the above. When
    this one finally bites it, I'll most certainly buy another. It's the only
    piece of technology that I've used daily for this long, which still works.
    To the OP: there's probably a catch on the battery clip that you have to
    squeeze in order to get it to pop off. Examine it carefully with a
    magnifying glass (I used a jewelers loupe. It had been so long since I
    replaced the battery, I forgot the drill....).
    jak
  11. NSM
    NSM Guest
    Wanna see my dead Casio museum?
  12. NSM
    NSM Guest
    Yep. My buddy and I both got Casio watches that had a full
    scientific/programmers calculator built in, but they both died as the
    buttons failed.
  13. Same here. I paid 50 cents for my Casio at a garage sale. I think it's
    still on the original battery after at least 8 years. I gave up on the
    band and just keep it in my pocket. It's one of those with 32 phone numbers,
    multiple alarms, stop watch, timer, dual time zones, etc. :) I have a spare
    that has the calculator. ;-)
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    ignored unless my full name is included in the subject line. Or, you can
    contact me via the Feedback Form in the FAQs.
  14. jakdedert
    jakdedert Guest
    Contact me offline...I'd like to *have* your dead Casio museum.
    jak
  15. jakdedert
    jakdedert Guest
    I'm trying to visualize the arrangement of the buttons. I had the same
    problem, but fixed it. IIRC, it involved cleaning out some external gunk on
    the pins themselves, which limited full travel.
    I remember that the last time (recently) I changed out the battery, I
    tweaked the switches on the internal module as well. Mine works perfectly
    15+ years later. Of course, it has the old style incandescent backlight,
    which is fairly useless...but it 'does' light when I push the button.
    jak
  16. jakdedert
    jakdedert Guest
    I wash mine every time I wash my body <g> It stays on my arm except to
    clean underneath....
    It doesn't have any 'fancy' features...basic alarm, stopwatch, calender.
    What it 'does' have is a display which shows *all* of the time/calender
    information at a glance...no button pushing: time, am/pm, date & day of
    week. I only have to keep in my head what year it is.<G>
    Some day I'll find another like it, with bigger digits (and a better
    backlight). Fifteen years ago, I could read all of it a bit more easily.
    jak
  17. Yes, this has happened to me too. It's not all that different from
    the gunk that gets inside the remote control, except in the case of
    the watch it's getting in the way of the mechanical action rather than
    the switch itself. I think I took out the module, and then applied
    some rubbing alchohol to the switch actuators in the case.
    Though given that the original poster says the buttons never worked
    from shortly after he got it, I'm not sure when there'd have been a
    chance to accumulate the gunk.
    Michael
  18. Franc Zabkar
    Franc Zabkar Guest
    I had a Casio scientific calculator watch about 20 years ago. I think
    it lasted about seven years and failed for the same reason.
    I also had a Casio organiser (SF5300) that died when the flex cable
    failed.
    - Franc Zabkar
