Replacement for TA7200
Discussion in 'Electronic Components' started by Johan, Jul 18, 2007.
  1. Johan
    Johan Guest
    I need a replacement for TA7200.
    If there is no direct equivalents, then I want to make a "converter-board",
    using an IC with similar specs, and fit this board into the place of the
    original TA7200.
    So....what IC's can I use for this ?
    Please reply to my mail:
    (I'm not in here very often)
    Thank you.
  2. Franc Zabkar
    Franc Zabkar Guest
    The NTE web site suggests NTE390 as a replacement, but this is an NPN
    transistor, not an IC. OTOH my paper NTE catalogue suggests the
    NTE1153 (= ECG1153).
    This URL suggests RCA SK3283 as an equivalent:
    http://www.weisd.com/store2/NTE1153.html
    I'm not sure about this one, but you could have a look at the TA7205
    (4 ohm, 18V):
    http://www.nteinc.com/specs/1100to1199/pdf/nte1155.pdf
    http://www.datasheetarchive.com/datasheet.php?article=3215863
    Or TA7200 / TA7204 / TM1153 Audio Power Amplifiers:
    http://malzev.tripod.com/comp/ta7200.htm
    - Franc Zabkar
Similar Threads
Loading...
