Replacement diff bus xcvr?
Discussion in 'Electronic Components' started by John E., Mar 8, 2007.
  1. John E.
    John E. Guest
    The part that has failed has these markings:
    LS1176
    8AT
    D5HT
    This is the data sheet for it, I think:
    SN65ALS1176:
    <www.cgi/http://www.allcomponents.ru/pdf/ti/sn65als1176.pdf>
    although how to I tell if the failed one is a 65 or 76 prefix part?
    Searching local suppliers, I find this:
    SN75LBC176A:
    <http://www.jameco.com/Jameco/Products/ProdDS/251053TI.pdf>
    Is the second a suitable replacement for the first?
    Package is SOIC.
    They're both TI, so why the different numbering (1176 vs 176)? What does
    65/75 prefix indicate? And regarding the other markings on the failed IC:
    does HT mean Hi-Temp?
    A few too many discrepancies in my mind to just swap it in just yet.
  2. John E.
    John E. Guest
    That should read "...is a 65 or 75 prefix part?".
  3. Franc Zabkar
    Franc Zabkar Guest
    This is TI's page:
    http://focus.ti.com/docs/prod/folders/print/sn65als1176.html
    This is TI's search page:
    http://focus-webapps.ti.com/general/docs/sitesearch/searchdevice.tsp
    Searching for parts containing "LS1176" at TI's web site finds only
    the SN65ALS1176.
    See TI's documentation:
    http://focus.ti.com/docs/prod/folders/print/sn75lbc176a.html
    The LBC devices appear to be upgrades to their respective ALS
    versions. They specify lower power and improved ESD.
    The 65 versions appear to have a wider operating temp range (-40C to
    125C, -40C to 85C) than the 75 versions (0 to 70C).
    The datasheets are here:
    http://focus.ti.com/lit/ds/symlink/sn65lbc176a.pdf
    http://focus.ti.com/lit/ds/symlink/sn75lbc176a.pdf (same as previous)
    http://focus.ti.com/lit/ds/symlink/sn65als1176.pdf
    All devices have an SN75176 "footprint".
    - Franc Zabkar
