I am trying to replace some leaky capacitors from an Abit motherboard. Can I
substitute the electrolytics with some other kind of similar values? Thanks for
your help.
regards
hg.
Yes, You can replace them with other brands as long as you use low ESR
types. Also, using the 105C types will last longer in a higher
temperature environment which in many cases is the cause of short lived
caps.
You most likely won't need low ESR cap's every where in the MB how
ever, they tend to be of a much better quality which over time pays
off with the price difference.
I think at some point, high ESR caps may just lose the market since
every one these days is looking towards low ESR in most applications
needed or not.
I remember once replacing some caps in a small PS unit that would not
fire up with low ESR types because the design assumed a small ripple at
initial start. it detected what it thought was a short and refuse to
start reliably. The fix was to place a 0.1 ohm r in series with one of
the caps that was in the sensing circuit.
