Replace IC 4049
Discussion in 'General Electronics Discussion' started by colum, Jan 8, 2021.
  1. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
  2. colum
    colum
    136
    4
    Jul 25, 2013
    The 4049 goes to the Transistors with 5V pulsing on each leg that had been 10 V but was divided by the 4027
  3. colum
    colum
    136
    4
    Jul 25, 2013
    I may have an incomplete diagram, I do not see any and the role of capacitors are confusing at least for me
  4. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
    Hello,
    You could also use IRL540 mosfets.
    Those are logic gate mosfets that are fully open at 5 Volt on the gate.
    Bertus
  5. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
    Hello,
    Decoupling capacitors ate there to have a stable working of oscillarors and logic circuits.
    The 555 will need a 10 uF and a 0.1 uF accross the power lines.
    Also you need the capacitors on the 12 volts regulator to avoid oscillations from the regulator:
    Bertus
  6. colum
    colum
    136
    4
    Jul 25, 2013
    The supply starts off as 10 V and then is split with the CD4027 to 2 X 5V
  7. colum
    colum
    136
    4
    Jul 25, 2013
    That is how its hooked up except that the 10uf is lower
  8. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
    Hello,
    The 4027 will NOT divide the voltage , it will divide the frequency.
    The outouts will have the same amplitude as the powersupply.
    When used as a divider the outpouts will alternate at half the frequency.
    Bertus
  9. colum
    colum
    136
    4
    Jul 25, 2013
    Thank you for that valuable information. I have decided to go back to square one and find a diagram that will drive a various speed synchronous motor
    I think I will beg someone in these forums to send me one
    Your advice is much appreciated...colum
    davenn likes this.
  10. WHONOES
    WHONOES
    1,017
    276
    May 20, 2017
    One thing that nobody has mentioned is the very limited source / sink currents available from CMOS logic.
  11. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
    Hello,
    The PDF in post #18 shows the driving specs of several chips.
    Bertus
  12. Frankchie
    Frankchie
    124
    15
    Nov 14, 2017
    I wonder if the 4049 had proper bypass caps directly across its power pins.
    About 40 years ago I had a similar perplexing problem that drove me nuts for days. Out of desperation I added a 0.1uf bypass cap and the problem disappeared. As I recall I was using TTL logic chips, but I believe similar bypass caps are recommended for CMOS logic chips.
    bertus likes this.
  13. bertus
    bertus Moderator
    1,312
    513
    Nov 8, 2019
    Hello,
    @Frankchie , That is why I mentioned the decoupling capacitors in post #21.
    Bertus
  14. Audioguru
    Audioguru
    3,042
    678
    Sep 24, 2016
    The datasheet for the CD4049 shows that with a 12V supply its typical average output sink current is 25mA and its source current is 12mA per inverter. The circuit has 3 times those currents with the 3 inverters in parallel.
  15. Harald Kapp
    10,802
    2,436
    Recommended for any chip. No matter whether analog, digital, bipolar, MOS ...
    These bypass capacitors serve to supply an initial surge current when the chip's interbl transistors switch. This surge current canot be supplied very well by the traces of a PCB. Therefore the decoupling capacitors need to be placed near to the supply pins of the chip, ideally right next to the pin and need to be conneced to the supply voltages and ground (0 V) with traces as short as possible.
    In very high frequency circuits it is even customary to use different capacitors (e.g. 100 nF, 10 nF and 1 nF) in parallel to optimize the frequency response of the three.
  16. colum
    colum
    136
    4
    Jul 25, 2013
    Thanks Harald I'm going to redo the entire circuit with more capacitors and more test points ...colum
