Repairing speakers
Discussion in 'Troubleshooting and Repair' started by McDroogie, Jan 25, 2013.
  1. McDroogie
    McDroogie
    37
    Dec 25, 2012
    I picked up a pair of speakers. The main speaker has an out for the other. However when I run them the output speaker works fine, but the main one only works when I jiggle its cord? Is there anything can try to fix it? When I use the second one as a stand alone I don't get the same quality because I can't adjust the bass and treble.
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Can you take a picture of the speakers and show the faulty cord.
    I presume that one speaker has an internal amplifier, is this so?
    What is the power supply?
    It sounds as if you have a bad connection, perhaps a cable has been tugged or it has been wiggled about so much that the wire has broken, if so, you will need to remake the connection.
  3. McDroogie
    McDroogie
    37
    Dec 25, 2012
    I'm using an external 9V power supply. It's pretty loose. And the main speaker has an internal amp; it's also the faulty one.
  4. McDroogie
    McDroogie
    37
    Dec 25, 2012
    Here are some pictures.
  5. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Your first picture is too black to see anything.
    The second pictur shows a cable bent in a way that no cable should be bent. The tail is there to make the bend much less abrupt.
    You do not say what this cable does, you could remove it and measure the connections end to end and then if there is a fault, remake the cable end, possibly using a new plug.
  6. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    In general, if there is an intermittent problem that comes and goes when you bend a particular cable, it is due to either a break somewhere along the cable, a break in the cable at or near the point where the cable enters the strain relief on the plug (and I use that term loosely; often the so-called strain relief on cheap cables is too rigid to relieve any strain and just creates a weak point where the wire emerges from it), within the plug (less common), between the plug and the socket (uncommon) or between the socket and the circuit board (this can happen if the item is dropped and lands on the plug; the circuit board can be broken and/or the solder joint(s) on the plug can break.
    That should all be fairly obvious, as is my suggestion to gently wiggle the wire and plug in various places to locate the break as accurately as possible.
    From your description it seems that the power is OK because the second channel of the amplifier (that drives the daisy-chained speaker) always works; it's only the channel that drives the first speaker that is having problems. The connection from the amplifier to the speaker is inside that enclosure and unlikely to be the problem.
    My guess would be that there's an intermittent break in one channel in the wire that runs from the main speaker to the signal source. I assume this ends in a 3.5 mm stereo plug that can plug into a laptop, iPod, etc. As I said, the break is likely to be right where the wire leaves a strain relief, either at the speaker end or at the plug, and you can locate the break with gentle wiggling.
