Repairing power supply of MOXA Nport5610
Discussion in 'Troubleshooting and Repair' started by TomerG, Jul 2, 2013.
  1. TomerG
    TomerG
    3
    Jul 2, 2013
    I'm working with this serial to ethernet MOXA.
    After power outage, the MOXA couldn't power up again.
    There is a separate Power supply circuit inside so I checked the power in (220v) is ok, but there is no power out.
    I think maybe the capacitor blown up (two capacitor at the right side)
    attached the circuit picture.
    Can somone tell where can i get a datasheet for it?
    Or does anyone got this problem in the past?
  2. davenn
    davenn Moderator
    13,785
    1,936
    Hi
    welcome to the forums :)
    the output caps often overheat and fail in these switchmode power supplies
    replace both of the ones on the right and chances are it will work
  3. (*steve*)
    25,480
    2,827
    And you can see that one of the filter caps has started to leak.
    I would second Dave's opinion
  4. TomerG
    TomerG
    3
    Jul 2, 2013
    Thanks you very much for the quick answer.
    I will try to replace them and update.
  5. (*steve*)
    25,480
    2,827
    Be sure to choose 105C rated low ESR capacitors. Also choose a reputable brand/supplier.
  6. TomerG
    TomerG
    3
    Jul 2, 2013
    I've replaced both capacitors at the output and the big capacitor at the input, but still there is no output voltage. maybe it's the stabilizer?
    Another thing, there are two different lines at the output, and both of them connected to the board, why is that? why the board need two different input with the same voltage?
  7. (*steve*)
    25,480
    2,827
    Either that or the thronomister*.
    That will be to supply the required current.
    Check that the fuse hasn't blown. If it has, then chances are the chopper transistor has failed.
    * A device as nonexistent as "the stabilizer"
