D
Daniel Who Wants to Know
I was recently given an old early '90s model electric wheelchair that had
sat for several years in storage and during that time the pair of 60Ah 12v
batteries were allowed to completely discharge to zero terminal voltage.
There was acid in the bottom of one of the battery boxes that told me that
it had been previously overfilled and then charged in the past causing it to
overflow. I managed to bring them back to life by putting them on a 1.25
amp trickle charger for a half hour each which brought the terminal voltage
up high enough for the wheelchair's own 8 amp smart charger to recognize
them. That charger started out at 1 amp and slowly ramped up to the full 8
over a period of several hours. My only concern is that I had a "brain
fart" of sorts and forgot that the acid volume increases during charging and
managed to fill the cells to the full line before charging them causing me
to have to remove some from each cell during charging to keep them from
overflowing. Now I have 600ml sitting in a plastic cup waiting to be added
back in as needed as the battery naturally loses water. I don't have a
hydrometer or a digital multimeter at the moment and I need to know what to
do next. All 12 cells gas at the end of charging but they gas uneven
amounts which tells me that the specific gravity is uneven. I am thinking
of draining all of the acid into a large container then stirring to mix it
up and refilling the battery with that. Any advice other than buy a good
hydrometer would be appreciated along with ways to reduce the amount of
sulfation that I know has to be present.
BTW yes I know how to safely work with sulfuric acid without blinding or
burning myself and I have a box of baking soda nearby for spills.
