Repairing a USB 2.0 hub
Discussion in 'Electronic Repair' started by Man-wai Chang, Apr 15, 2011.
  1. What most likely kill the hub? Could it be repaired in general?
    It's a Samsung PUH-7000NB.
    @[email protected] Might, Courage, Vision, SINCERITY.
    / v \ Simplicity is Beauty! May the Force and Farce be with you!
    /( _ )\ (x86_64 Ubuntu 9.10) Linux 2.6.38.2
    ^ ^ 17:31:01 up 11:42 0 users load average: 1.07 1.07 1.05
    ä¸å€Ÿè²¸! ä¸è©é¨™! ä¸æ´äº¤! ä¸æ‰“交! ä¸æ‰“劫! ä¸è‡ªæ®º! è«‹è€ƒæ…®ç¶œæ´ (CSSA):
    http://www.swd.gov.hk/tc/index/site_pubsvc/page_socsecu/sub_addressesa
  2. Hubs are so cheap -- most are made in <ahem> China -- you might as well
    replace it.
    This might also be a good time to put a USB 3.0 card in the computer.
  3. Sylvia Else
    Sylvia Else Guest
    Presumably it's powered by a plugpack, which may have died, and be
    replacable with something equivalent from your local electronics store.
    Otherwise I'd expect it to be beyond salvage.
    Sylvia.
  4. Considering your location...what would it cost you to replace?
    Don't wanna waste it *IF* it could be repaired easily... :)
    ^ ^ 20:51:01 up 15:02 0 users load average: 1.04 1.08 1.12
  5. Sylvia Else
    Sylvia Else Guest
    If you take it apart, you'll likely find that it consists of a single IC
    and four USB sockets soldered to a board. There *might* be some capacitors.
    There's not a lot there to repair.
    You did try a different cable didn't you?
    Sylvia.
  6. Tony Hwang
    Tony Hwang Guest
    Hii,
    Is you time that cheap? New one may cost ~5 bucks.
  7. Extra credit: Calculate the cost of handling a zero cost repair.
    We are caught in a dilemma... If stuff is made to a high quality standard,
    then it won't break down very often, and won't need the repair. But -- to
    some degree -- we need stuff to break down to encourage people to buy new
    technology, which appears at an ever-faster rate.
  8. Smitty Two
    Smitty Two Guest
    Paperwork, sure. But charging your customers to clean up the mess on
    your bench? I wouldn't be advertising that ...
  9. A. Baum
    A. Baum Guest
    I have two 2.0 hubs I'll send you for free.
