Repairing a set top box.
Discussion in 'Electronic Repair' started by moo, Sep 5, 2012.
  1. moo
    moo Guest
    Hi all, new to this forum an electronic device repair. I have been given
    a few items that are faulty to learn repair on and I currently am
    working on a set top box the picture comes up fine but when I go to scan
    the channels the signal strength is exactly 0 nothing at all, I have
    tested various points on the board for voltage with a fluke and it all
    checks out, the cables are fine. And im assuming the rf modulator box is
    as well because im getting the display on screen when I plug the RF
    cable in from the wall. Just no signal strength. I at a bit of a loss as
    to where to start looking and cant find a service manual online to give
    me any clues. the board is marked as DVB-TH MB04 rev 1.2. Some jaycar
    product bought a few years ago. If someone could please point me in the
    right direction it would be very much appreciated.
    Thanks for your time.
  2. moo
    moo Guest
  3. N_Cook
    N_Cook Guest
    First you have to check whether it has fallen foul of not enough EEprom for
    the current useage,
    "Split NIT "
  4. moo
    moo Guest
    Thanks :) I just done a bit of googling about so Im onto this Split NIC
    suggestion. If it is the case is it a matter of rewriting the eeprom, or
    essentially does the change in freeview spec make this a paperweight?
  5. moo
    moo Guest
    does the change in freeview spec essentially make this a paperweight?
  6. Adrian C
    Adrian C Guest
    I think 'Spilt NIT' is a UK issue.
    Are you in Australia?
  7. moo
    moo Guest
    Yes im from Australia I noticed a few things about the uk having the
    issue but cant find much about Australia.... noticed the tuners are
    quiet loose so im going to take a shot a replacing them and go from
    there.... Thanks for your input.
