Repairing a DC power supply
jkm89
May 19, 2013
May 19, 2013
Greetings,
I recently purchased a few surplus HP 6266B DC power supplies: http://www.google.com/url?sa=t&rct=...PGBiDn3ahCd-rQ7YPOqryHw&bvm=bv.46751780,d.cGE
Some of them work, but others are exhibiting relatively strange behavior. One of them does not work at all, (no voltage is produced), and another one has a voltage, but the voltage increases very slowly. If I turn it up to its highest setting, It takes several minutes to get up to half of its max voltage.
Has anyone else had a problem like this? I was thinking about changing out some of the capacitors, because I feel like they would be the most likely to fail. Any other ideas?
Thanks in advance.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
I would follow the instructions for troubleshooting the device.
If that doesn't show anything, start at the secondary of the mains transformer and work forward checking voltages.
You've got a full schematic and HP gear was generally very well built.
If it does turn out to be a capacitor problem you may be able to see that when you open it up.
