Dave_s said:
Paul and others,
http://s1001.photobucket.com/albums...rrent=Water-inside-solar-garden-lamp-CORR.jpg
My Solar Lamp has no inductors that suggest a "Joule Thief" circuit is
used. My LED is orange, not white.
I tried to use run your netlist with my LTSPICE 4. Only get error message
"multiple instances of SYMATTRIB".
I copied your netlist into NOTEPAD and saved as SOLAR_JOULE.CIR.
Can youi suggest what else I can do to run your LTSPICE JOULE_THEIF
FILE"?
It is not a netlist (.cir or .net). It includes graphical information for
the schematic and should be saved as ASC. The inductor I used is a Cooper
DRQ74-101 which is a 10/40 uH coupled inductor in a 7.5mm SMT package. I
have attached a simpler version which delivers about 20 mA into a 6V LED
load with battery voltage from 2V to 5V, and 10mA with 1.5V.
The pcboard looks full of water damage salts. After cleaning with
SIMPLE_GREEN and ALCOHOL, the repaired board does not make the LED turn
on.
Is the base bias resistors, 15K and 100K setting the threshold for LED
turn-on at sunrise?
I did not see your schematic previously. It does not seem quite right. The
first transistor seems to be used to turn off the second transistor when
the solar cell is producing current. The large diode is usually used to
keep the battery from backfeeding into the photocell when it is dark. It is
possible that a second photocell could be used just to detect light, but
unless it is just a tiny device it does not seem correct. The 15k resistor
should be connected to the photocell, but the 3k resistor and LED should be
connected to the battery. The photocells might be connected in series to
give enough voltage.
My schematic is suspicious since there is no current limiting resistor
between LED and SOLAR CELL VOLTAGE. They cannot possibly be running the
LED directly off the battery without current limiting?
The battery is probably connected through a current limiting device to the
LEDs and the photocell. It also needs to be configured so that the
photocell charges the battery but disconnects the LED load when it is
providing current, and then connect the LEDs to the battery when it is
dark.
Here is a link to two circuits for solar powered garden lights:
http://talkingelectronics.com/projects/SolarLight/SolarLight.html
And here are more circuits, ranging from simplest possible to one that uses
a microcontroller:
http://www.evilmadscientist.com/article.php/solar
Paul
====================== JouleThief1.ASC ==========================
Version 4
SHEET 1 880 680
WIRE 80 0 -112 0
WIRE 208 0 80 0
WIRE 80 16 80 0
WIRE 208 16 208 0
WIRE 80 112 80 96
WIRE 208 112 208 96
WIRE 256 112 208 112
WIRE 368 112 320 112
WIRE 560 112 368 112
WIRE -112 128 -112 0
WIRE 368 128 368 112
WIRE 208 176 208 112
WIRE 560 192 560 112
WIRE 368 208 368 192
WIRE 80 224 80 192
WIRE 144 224 80 224
WIRE 80 256 80 224
WIRE 240 304 144 304
WIRE 368 304 368 272
WIRE 368 304 320 304
WIRE 400 304 368 304
WIRE 496 304 400 304
WIRE 496 320 496 304
WIRE -112 384 -112 208
WIRE 80 384 80 352
WIRE 80 384 -112 384
WIRE 208 384 208 272
WIRE 208 384 80 384
WIRE 400 384 208 384
WIRE 496 384 400 384
WIRE 560 384 560 256
WIRE 560 384 496 384
WIRE 560 416 560 384
FLAG 560 416 0
SYMBOL npn 144 176 R0
WINDOW 0 33 47 Left 0
SYMATTR InstName Q1
SYMATTR Value 2N3904
SYMBOL ind2 96 112 R180
WINDOW 0 36 80 Left 0
WINDOW 3 36 40 Left 0
SYMATTR InstName L1
SYMATTR Value 20µ
SYMATTR Type ind
SYMBOL ind2 192 0 R0
SYMATTR InstName L2
SYMATTR Value 20µ
SYMATTR Type ind
SYMBOL LED 352 208 R0
WINDOW 3 76 25 Left 0
SYMATTR Value AOT-2015
SYMATTR InstName D1
SYMBOL res 64 96 R0
SYMATTR InstName R1
SYMATTR Value 4.99k
SYMBOL voltage -112 112 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value 2
SYMBOL LED 352 128 R0
WINDOW 3 74 35 Left 0
SYMATTR InstName D2
SYMBOL res 384 288 R0
SYMATTR InstName R2
SYMATTR Value 27
SYMBOL npn 144 256 M0
SYMATTR InstName Q2
SYMBOL res 336 288 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 34 46 VTop 0
SYMATTR InstName R3
SYMATTR Value 499
SYMBOL cap 480 320 R0
WINDOW 3 31 47 Left 0
SYMATTR InstName C2
SYMATTR Value 10µ
SYMBOL schottky 256 128 R270
WINDOW 0 32 32 VTop 0
WINDOW 3 0 32 VBottom 0
SYMATTR InstName D3
SYMATTR Value 1N5818
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL cap 544 192 R0
SYMATTR InstName C1
SYMATTR Value 220n
TEXT 272 40 Left 0 !K1 L1 L2 1
TEXT -96 408 Left 0 !.tran 2m startup
