Hello,
I have an echo Sounder Target from NASA Marine and a problem.
Inside there is a resistor which is burned down. No chance to get the color code.
Now my question:
Does anybody know a source to get the circuit diagram or
does anybody have the same echo sounder and can tell me which value this particular resistor has (resp. the color code)?
Or any other idea to get the correct value?
Attached there are two pictures with a circle around the particular resistor position.
The sounder was built 1992 (found on the PCB).
Thank you for your help (I hope so)!
In advance,
Christian
Now my question:
In advance,
Christian
