Renewable Energy (part 2)
Discussion in 'General Electronics Discussion' started by davez, Oct 25, 2014.
  1. davez
    davez
    27
    Oct 11, 2014
    Hi guys Im creating another wind turbine generator do you have sample projects that you made yourselves? because Im having a hard time finding a schematic diagram for a wind turbine generator.
  2. Bluejets
    Bluejets
    4,673
    984
    Oct 5, 2014
    I just Googled "home built wind generator" and came up with enough reading to last a lifetime.
    (*steve*) and KrisBlueNZ like this.
  3. davez
    davez
    27
    Oct 11, 2014
    What motor should i use for me to charge a 12v battery?
  4. (*steve*)
    25,482
    2,830
    You will probably need a motor that operates from greater than 12V. Also, since wind turbines are generally low RPM, you will either need a gearbox or to rewind the motor to generate higher power at low RPM.
  5. davez
    davez
    27
    Oct 11, 2014
    :confused: rewind?? so i need to find a motor that is 12v higher?
  6. BobK
    7,682
    1,688
    Or you could use a boost converter if you get less than 12V from the turbine.
  7. (*steve*)
    25,482
    2,830
    MPPT can also be used with wind turbines
  8. Externet
    Externet
    759
    165
    Aug 24, 2009
    What voltage and amperage are you aiming to ? For what purpose ? Charging an automotive battery ?
    Find a discarded thread mill and use its permanent magnet DC motor as generator. Run it at the highest rpm you can.
