removing silicone from a circuit board
Discussion in 'Troubleshooting and Repair' started by kurtm, Dec 13, 2010.
  1. kurtm
    kurtm
    Dec 13, 2010
    hello all,
    I have these circuit boards that I need to repair, but they are covered in a thin layer of a silicone type material.
    What type of solvents or cleaners are ok for electronics? Rubbing alcohol maybe?
    thanks for the help
  2. (*steve*)
    25,482
    2,830
    Can you peel it off?
    Isopropyl alcohol is normally my choice of alcohol and it is reasonably safe for most components.
    Rubbing alcohol is mentioned as a great thing for cleaning up silicone caulk, but that is when it's not cured. But I'm pretty sure that silicone (if that is what it is) will not be affected by it once cured.
    Also, it's almost certain that it's not a nomal silicone material that you can get a t a hardware shop. That stuff releases chemicals that will eat your components while curing (acetic acid is a weak acid, but it's still an acid). This is an issue if you want/need to replace it.
    Sorry that my reply isn't really helpful.
  3. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Cured silicones, whatever type, can not be removed other than by mechanical means.
    Gasoline will make silicones a little jelly-like after long exposure but you don't want to expose your electronics to gasoline for days.
    Do you need to remove all of it? And like steve says, if you need to replace it you'll have to use a 2-component silicone.
