removing silicon
Discussion in 'Off-Topic Members Lounge' started by donkey, Sep 21, 2012.
  1. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    this isn't electronics as such but I have acquired some fish tanks and they have dividers siliconed in place, I was looking at an easy way to remove the silicon to get the dividers out. any one got an idea?
  2. Alf
    Alf
    Sep 21, 2012
    REMOVING PANELS SILICONED INTO FISH TANK
    Hi Donkey, This is an interesting application... perhaps go to your local graphic arts supply and get some thin Music Wire which I believe K&S Engineering provides as a product .... thread it in between the edge of the glued plate and the tank side.... grab both ends of the wire with a pair of pliers and saw back and forth...
    You really need something that is about 0.005 dia which may require a specialty search...
    318am .... I am tired but just happened to see your thread.. this is my first attempt at a solution... I will sleep on it.... let me know of your progress
  3. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Single edged razors, just slide it flat across the surface of the glass...
    [​IMG]
    For the final pass, you might find that some oil (probably vegetable oil in your case for toxicity reasons) will allow you to glide over the surface easier and also makes it possible to literally scrub the remaining residue film off with a cotton rag and a little work... When I did shower enclosures we used mineral spirits for the 'oil' but I wouldn't suggest that for your application...
  4. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    I'd use CocaCola's remedy.
    I've known people that used chemicals to clean their tanks, or effect leak repairs that
    ended up killing the fish when they were returned to the tank.
    You have to watch that.
  5. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Yeah cross contamination is a real concern when dealing with fish... Thus the use of vegetable oil... For oil clean up I would use ethanol, again sticking to something less 'toxic' just in case of some cross contamination... The razor alone might do just fine if you use a fresh one and do multiple passes... I just find that scrubbing the last bit of residue with a rag and lubricant to work better in most cases... BTW the lubricant doesn't actually effect the silicone per say what it does is to coat the glass surface and prevent the silicone from 'clinging' back, something that can be quite annoying when attempting to clean...
  6. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    very insightful thank you all
Similar Threads
Loading...
