D
DGoncz 22044-0394
MOEPED #3 is mechanically stable and more than half of the onboard 110 VAC
systems are on line.
MOEPED stands for MObile Experimental Physics Educational Demonstrator. It's
my project for one repeated credit at the community college Seminar and
Project in physics, PHY 298, with Dr. Majewski. It is a 2004 Lightning Cycle
Dynamics (www.lightningbikes.com) Thunderbolt recumbent, their base 7-speed
model, with several transmission changes.
First, there is the tandem crankset. Providing a 51 tooth cog on the left
side lets me drive a modified Surplus Center (www.surpluscenter.com) 10-1134
"impedance protected" (stall proof) ceiling fan motor with bike chain at
about its design rpm, or drive the pedals from the motor. Driving the pedals
from the motor helps debug the wide-range 24-35-51 / 11-34 gearing. Driving
the motor from the pedals should produce AC when patched correctly but it
doesn't and that is what this post is about. Pics are at
ftp://users.aol.com/DGoncz/Bicycle/ACMotorGenerator/
Second, the rear hub has been replaced and relaced with an 8 speed disc hub,
7 cogs, a spacer, and a Big Cheese spider to carry chain rings on the left
side. A 48 tooth cog drives an Ametek servo motor from C&H sales
(www.candhsales.com) rated 30 VDC, 12 A stall, 900 rpm, which drives a Radio
Shack inverter (www.radioshack.com) rated 140 W, 10-15 VDC, 2.4 W idle. The
pinion is 8 teeth, comes from Northern Hydraulic, who I think are at
(www.northerntool.com) and has been thinned to 2 mm and chamfered. The motor
mount is made from plastic drain pipe, hangs from the seat stay clamps, and
is tensioned from the seat brace. An aluminum motor mount is in the works.
The bike has been fitted with an ESGE dual leg kick stand, *backwards*.
Lighning has accepted this recommendation for their customer tip file. I
have not seen it in print. The bike stands on its own, and a bit of wood
underneath with two pocket holes captures the legs when you want to pedal
and prevents spreading of the kickstand legs. Two extra long spokes will soo
n be fitted to the stand legs to snag the chain stays with the spoke heads,
and wing nuts will tighten the spokes to lock the stand, allowing seated
pedaling. It will take five minutes to set up once parked.
To proof the power generating ability of the system I plugged the motor into
the inverter and went for a ride. As expected, it was a dynamic brake, but
nothing blew up. The system could generate say 20 watts all night long while
riding and you'd hardly notice it. I've run a fluorescent lamp from the
inverter. I could run my laptop from it but I don't have a padded case yet.
My question to the readers of alt.engineering.electrical,
rec.crafts.metalworking, sci.electronics.design, and sci.electronics.repair
is:
Given this is an impedance protected ceiling fan motor with many turns of
fine wire, and I have invested four years of effort, and the system is
stable, is it now time to rewind the stator with fewer turns of thicker wire
to optimize generator function, as it is not likely that this motor will
ever be stalled, or should I continue to try various cap combinations,
driving the AC motor/generator from the DC motor in reverse, or should I run
a sweep to find out what is going on and *compute* an optimized cap? I'm
leaning toward rewinding the stator. It seems like an idiot proof motor
would make a lousy generator.
The motor run cap is currently 5 microfarads. The self-excitation cap is
currently 30 microfarads. Currently the motor runs right as a motor, but
only generates 0.1 VAC at best speed when patched as a generator, even when
I "whack" it with DC while cranking as described in Lindsay's "Alternator
Secrets". I suspect there's just too many turns of wire in there. I have an
audio amp and can download Daqarta again for a sweep. I have a Tek 541 scope
with CA plug in. Soon all these and the bike will be under one roof.
Yours,
Doug Goncz
Replikon Research
Seven Corners, VA 22044-0394
is:
Yours,
Doug Goncz
Replikon Research
