Categories
Platforms
Content
Olfa blade, Xacto Knife, Scissors, Pliers, Robust Wire-cutters or side-cutters, a Drill, Soldering iron...Circuit boards are attached to white plastic & can be difficult to remove the board.Is there a tool that can be purchased to make this task easier?
There are soo many options, you need to share more details.
Pictures?
You can break, cut, unclip, or melt the plastic to get the board out.
If you mean those locking/snap-in buggers,they are a pain to open.
Since they come in many sizes it will be hard to have a single tool to handle all.
A metal hollow tube
Maybe I'm missing something, but the arrow-locking type usually just needs you to use a pair of needle nose pliers to compress.
You squeeze the two sides of the lock with the needle nose, and pull-up the PCB at each post, one after the other.
