Remove back of monitor?
Discussion in 'Electronic Repair' started by Mr. Land, Oct 27, 2003.
  1. Mr. Land
    Mr. Land Guest
    I want to make some internal adjustments to an Acer 7156E monitor.
    Is there any chance anyone out there can tell me how to get the back
    off of this bloody thing?
    I've removed the two screws from the back along the bottom of the
    unit, but the top edge of the back seems to remain firmly attached to
    the front frame. I've tried pressing the parts in every direction I
    can thing of, but the back refuses to come off.
    Thanks for any help...
  2. James Sweet
    James Sweet Guest
    There's probably some latches in the vents along the top that you can push
    in. What adjustments do you wish to make? If the problem happened suddenly
    then there's no adjustment that will fix it. Unless it wasn't well tuned to
    begin with, there probably isn't much you can do.
  3. uk-hamman
    uk-hamman Guest
    sorry dont know the monitor
    but sometimes , there are screws hidden behind
    the sticky labels , use your finger
    to press hard on the labels
    if they dinge in , then they may well be a screw behind it .
    but normally therre are about 4 screws holding a back on
    or at least 2 and 2 clips , normally the push type
    if you can open it a little try shining a torch down the open bit
    and try to see what is holding it / or where it is being held
    cheers
    de Paul
  4. Sometimes monitors have a clip-in cover on each side near the top that
    covers a screw.
    WT
  5. Mr. Land
    Mr. Land Guest
    Latches: yes, that's what I thought also. But I've pressed both the
    back itself and the plastic frame surrounding the CRT in every way I
    can think of...the sucker just refuses to detach. When the bottom
    screws are out, the back does seem to pivot up a bit, hinging along
    that top edge, but it'll only pivot so far before the bottom of the
    back hits the internal PC board on the bottom. It must detach along
    it's top somehow, but I can't get that to happen.
    Adjustment: this monitor has seen many hours of use. It's still
    produces a crisp picture, but it's brightness is greatly reduced (full
    brightness gives you a rather dim picture.) I've had success before
    with this by adjusting the G2 bias on the picture tube. I'm hoping I
    can make that adjustment to get a little more brightness out of the
    thing, while still keeping it reasonable sharp and in focus.
    Thanks very much for your reply.
  6. Mr. Land
    Mr. Land Guest
    No clips are visible. Just the two screws along the bottom. A torch,
    you say? Well, that'll certainly put an end to my problem!
    Unfortunately even though the back will pivot just a bit with the
    bottom 2 screws out, I can't make enough room to peek in there with a
    penlight, just isn't enough room.
    Thanks very much for helping...
  7. James Sweet
    James Sweet Guest
    Look closely, I fixed an NEC for someone at work a couple weeks ago and was
    having the same issue getting the back off. I noticed that the top was
    perforated with indentations that matched the vent holes further back, and
    finally noticed that 3 of the indentations along the edge were very slightly
    deeper and were in fact holes that I could push in with ballpoint pens to
    release the clips. I worked on a Nokia monitor once that was equally
    difficult to open. Why they can't just use normal screws is beyond me.
  8. Asimov
    Asimov Guest
    "Wayne Tiffany" bravely wrote to "All" (27 Oct 03 11:56:29)
    --- on the heady topic of "Re: Remove back of monitor?"
    Some monitors only have 2 screws on the bottom and an open hinge on the
    top. Simply remove the screws and swing the bottom up and off. The best!
    WT> From: "Wayne Tiffany" <>
    WT> Sometimes monitors have a clip-in cover on each side near the top that
    WT> covers a screw.
    WT> WT
    .... Over a hundred billion electrons were used in crafting this tagline.
  9. Mr. Land
    Mr. Land Guest
    Got it off! Two very persistent clips along top edge of back, had to
    twist the thing three different ways at once...thank you all.
  10. Joe Smith
    Joe Smith Guest
    and just think of all the casese that have been been removed by cottage
    industry,,,,,,,,,,,,,,,,;))
    j.
