Remote Control
Discussion in 'General Electronics Discussion' started by superdhebz, Feb 13, 2011.
  1. superdhebz
    superdhebz
    Feb 13, 2011
    I found this remote circuit: http://electrosofts.com/ehome/index.html#Remote
    I tried it but it didn't work, maybe because I used 2n2222 instead of BC177. I don't know if it's the reason why it's not working because my professor told me I can use 2n2222 for it since BC177 isn't available in the market.
    Can 2n2222 really be used in replace for BC177?
    Thanks!
  2. (*steve*)
    25,496
    2,837
    It should work fine.
    However that circuit shows the IR LED around the wrong way and also the series resistor is probably too high in value.
    Oh, and I would put the load in series with the collector, not the emitter.
    With all those errors, I would double-check the frequency is near what the TSOP1738 expects.
