Remote control not powering on! Help me please!
Discussion in 'Troubleshooting and Repair' started by DroneFisherMan, Sep 19, 2018.
  1. DroneFisherMan
    DroneFisherMan
    Sep 19, 2018
    Hi All,
    i am using bayangtoys X16 GPS drone.
    I managed to solder the "alfa APA-M04 7 dBi gain RP-SMA directional panel antenna Wi-Fi" on the board, and it was working absolutely fine. Until, I put hot glue on the antenna's solder to make it more solid.
    Since then , when I power on the remote the red light comes on for a second and beeps then it goes off. I removed the hot glue and still its doing same thing..
    Have I burnt the Tx?
    I have checked for any short on the antenna's ground and main wire, there is no short there. I have checked the battery and power, and all looks good.
    Could anyone help me out please!
  2. DroneFisherMan
    DroneFisherMan
    Sep 19, 2018
    the power does come up but then goes away, if I immediately power it off and power back on, then there is no LED,
    However, if I pause for 5-10 seconds the intensity of LED is high, and subsequently low if powered on during less intervals.
  3. bigkim100
    bigkim100
    67
    Apr 17, 2013
    I would suggest that you may have cooked the Bayang toys transmitter. Remove the added cicuit , and see if it works then...if not , you have cooked it. You would probibly do better using a cheap wireless wi-fi repeater.
