Joerg said:
Hello Michael,
Wow, you must yield a heck of a SNR out of that after they beefed up the
transmitter. I can barely receive it here in the office (California).
The clock only works on one wall and only in one particular spot. That
is because there is aluminum foil backed insulation in the walls. It has
to face a window and I have to make sure the screen isn't pushed over
that window at night or it won't receive.
How did you get the wires through the pipe joints? How many turns could
you squeeze in?
I used 22 AWG stranded hookup wire. I laid the wire on the ground
outside to let it relax in the hot Florida sun, then I put 100 8-32 hex
nuts on the end of the wire and squirted some old silicone "Solenoid
Lube" ('50s military surplus in lead tubes) into the pipe. I dropped the
wire with the nuts into the pipe and gently shook the pipe so the nuts
would go through the 90° corners. When the wire had made it through the
loop back to the starting point I tied the far end of the wire securely
to the outside of the copper pipe and pulled all of the wire through,
till it was tight. Then, like it says on the shampoo bottle, you repeat
the process till you run out of wire. I don't remember the number of
turns, but I am trying to get it dug out of storage and put it back up.
I am going to rebuild it, this time with a sweatable copper insulated
union made for a hot water heater and run the wires through the bottom
of the diecast electrical box. the fittings will thread together, and
provide more strength than the PVC coupling I used in the original
design.
The only antenna like that I ever made was round. When I bent the copper
pipe I pushed sand into it first so it would not flatten out too much.
Then I found out the sand was too moist and didn't want to come out so I
had to let it sit to dry for a week or so. That was before shop vacs
became ubiquitous.
I would have poured water through it to wash the sand out of the
pipe.
BTW, I used a shop vac to pull wire through a large conduit in 1970
when I ran electricity to my dad's garage in an underground conduit. It
was 1 1/2" so I tied a wad of paper towels to a thin rope and stuffed
them into one end, then taped the hose to the other end and turned it
on. You could hear the motor struggling at first, then it started to
move. Finally it popped into the canister of the shop vac a minute or so
later. I did this because the only fish tape available was a 50 foot,
and the run was about 80 feet and ran under the driveway and I didn't
want a pull box under the drive.
Another time I was installing the sound system in a new church. They
had waited till a week before their first service for us to install the
equipment. We quickly discovered that the general contractor had used
blown insulation, and had managed to fill a 200 foot run of one inch
conduit with blown insulation. (I think that they did it on purpose.) I
spied some of the tapered rubber plugs from the pre charged Freon lines
and that they were mostly hollow. I cut a hole in the tip and put it
over the nozzle of our large portable air compressor. I started pumping
compressed air into the pipe. It whined and changed pitch for almost
five minutes, then it started snowing the fine particles of insulation
in the church, and missing the tarps we had put under the pull boxes.
We swept up a couple 5 gallon buckets, then let the church vacuum up the
rest while we finished the job.
Its fun to find quick solutions to problems on the job.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
