RELAYS
Discussion in 'Datasheets, Manuals and Component Identification' started by njoroge, Jun 16, 2010.
  1. njoroge
    njoroge
    Jun 16, 2010
    hi i need relays used in LAL 1.25 AND 2.25 BOILER SEQUENCE CONTROLLERS
  2. davenn
    davenn Moderator
    13,948
    1,990
    Hi there
    Considering that probably none of us here are into boiler sequence controllers, maybe you can tell us a bit more about the type of relay you need.
    what operating (coil) voltage is required ?
    what voltage/current ratings do you need for the contacts ?
    Do you have one if these sequencers that has a dead relay in it ?
    if so can you get the info off that relay for us ? :)
    cheers
  3. njoroge
    njoroge
    Jun 16, 2010
    thanks dave.actually i want three but need one which i am going to describe.
    it is a 240 volts dc coil relay with two coils one wound on top of the other.it has three coil terminals one of which is common,it has a mechanical latch system.the contacts are about 10 amps 240 volts ac double pole double throw configuration.there is no info on the relay and it is not enclosed.
