relays
Discussion in 'Electronic Design' started by Sean Bartholomew, Aug 27, 2003.
  1. hi i have a circuit including a relay with a 5 volt coil voltage and
    drive current under 100mA.
    is there a solid state version i can use?
    a smaller and cheaper solution is what im looking for. this thing
    takes up way too much room. i tried a 4053 for switching but it doesnt
    work.
  2. well im switching the channels on a guitar amplifier. the channels
    switch when the sleeve of footswitch cable contacts the tip. i am
    replacing the standard footswitch with a different circuit. i have it
    working with the mechanical reed relay. id love it to work with an IC.
    Sean
Similar Threads
Loading...
