Relay with 50KHz, 1.9A rms?
Discussion in 'General Electronics Discussion' started by eem2am, Jul 6, 2013.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
  2. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    You mean kHz not KHz !
    The relay should stand the current but you do not say what voltage it is switching.
  3. (*steve*)
    25,496
    2,837
    Assuming the voltage is within limits for the relay, and that the load is not inductive, you shouldn't have a problem (OK, capacitive is an issue too).
  4. eem2am
    eem2am
    422
    Aug 3, 2009
  5. davenn
    davenn Moderator
    13,833
    1,950
    no, its just a standard relay coil
    no diode built in
    did something make you think that it was polarity consious ?
  6. davenn
    davenn Moderator
    13,833
    1,950
    eem2am
    GRRRRR
    stop starting new threads on the same topic!!
    now merged
  7. eem2am
    eem2am
    422
    Aug 3, 2009
    If i drive the coil of the 12V version of this relay from 24V, then is all i have to do is put a 1200R resistor in series with the relay's coil?
  8. (*steve*)
    25,496
    2,837
    A 12V zener is probably better.
  9. eem2am
    eem2am
    422
    Aug 3, 2009
    Thanks, is that something to do with the L/R timeconstant and getting the relay to "switch"
